Message 1 of 11
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi guys,
I'm looking for a way to reverse my animation clips in the time editor.
Hi guys,
I was used this. It opened the graph editor...i played around with the curve...it changed the timing of the animation but couldn't get it to reverse the entire clip.
The autodesk help says that the time warp is usually used for reversing clips...no guidance on how to manipulate the curve to get the result.
...tied that too
PM sent with link. thanks again
the clip isn't important, it's the workflow I can't get working. I have many to reverse.
Hi!
OK
- chosen "reservoir_wall_pours"
- added Time Warp
- set value for keyframe at 0 to 1749.289
- set value for keyframe at 1749.289 to 0.
Works absolutely fine here.
Right click to clip - Create Time Warp - and follow the steps
