Set object to WXYZ rotation like in Blender
SteveHibberd
Message 1 of 8
SteveHibberd
I'm trying to work out how to animate a Rubiks Cube.
In Blender you can set each cubes rotate order to WXYZ quarterian, job done animate any rotation you like.
How do you set this up in Maya?
Replies (7)
Message 2 of 8
mcw0
Message 3 of 8
SteveHibberd
I did find this info but it's not the effect I'm looking for in Blender you can set quaternion to the object Maya has to have it set to a curve thus giving a different result.
Try it:
Create 9x9 cubes
select one side and animate rotation at 90. Then select bottom row and rotate them 90. even setting the curves to Quarternion doesnt solve it.
Message 4 of 8
mcw0
No quaternions needed.  Simple rig.
Message 5 of 8
Baboonian
Share the scene, mcw ). very interesting
Message 6 of 8
mcw0
Unfortunately I'm unable to share the file.  But the basic approach is this...a constraint system.  You want each cube to be driven by one controller when it's in one orientation.  But then to switch to another controller on the next rotation.  The issue is once a controller is rotated, the next constraint target will have an offset.  All that's needed is to determine the next constraint target and reorient the constraint target after each rotation.  Obviously, this needs to be keyed for an animation.  Simple rig.  No quaternions needed.
Message 7 of 8
Baboonian
Hmm... thanks for the explanation. I tried using a direct connection to all cubs, and a condition defining the distance, but I got a cycle. And also orientation changes after a few rotations.
Well, I will research this subject.
Message 8 of 8
mcw0
@SteveHibberd Sorry, never did answer your original question.  And as you've mentioned, Maya's curve solution isn't really a solution.  There is no interactive quaternion tool that I know of.
As for animating a Rubik's cube, there's no need for quaternions.
