Announcements
Scaling a Lattice Rig?
Message 1 of 21
Hi all,
I'm rigging a cube using lattices. I have everything working nicely, but I've been running into problems using the "move_all" control that I have. When I do so, the cube bends towards the origin. It's probably a parenting or grouping issue, but I haven't been able to figure it out.
Replies (20)
Message 21 of 21
also, I think I have an understanding of the basics of joint orient from that, but I'd have to apply that a little more to be able to really understand it. It seems like it's, like you said, like having an extra control for your rotation. If I understand this right, if I had a character in a T pose, I'd want the joint orient to have 90 degrees on the z axis for the upper arm, that way the default values for the rotation are zero but the joint is still in place.
(edit: wow, 1 minute later in the video you do that exact thing)
