Rig Problem (Controller not aligned)
Message 1 of 14
Hello! Have been working on an animation and wanted to add some more movement before what I had already made. I had moved all of the keys forward and begin animating before the already made sequence. At some point, i switched perspectives and noticed that my root controller's translate X had been moved across all keyframes. The translation value remains the same, but the controller itself has shifted.
Anyway to go about fixing this? or should I just restart from and ealier file version
Replies (13)
Message 2 of 14
Attache your scene file in zip formate and send, will check
Message 3 of 14
Message 4 of 14
hi
Link not allowed me, send the maya file in zip format
Message 5 of 14
Message 6 of 14
zip the maya file and send. not link type.
Message 7 of 14
mspeer
Hi!
@Anonymous
You can directly attach ZIP files to a message here in the forum.
When writing an answer, please check below you text field for "Attachments" (+ Icon)
Message 8 of 14
Thanks!
Message 9 of 14
Hi
Some of your cog control group node have keys vales. so delete and put defualt value. its come normal. Pic attached.
Message 10 of 14
I'm I'm deleting my points from the wrong cog ctrl? (video attached)
Because deleting these points are doing nothing for fixing the hip position
Message 11 of 14
I don't understand whats going on with the file you sent me (picture above)
Message 12 of 14
Hi
Am telling cog control group.  not cog control.
Open your file what send me the maya file. you find the cog control group node keys.
also am attaching one image , pls see that  in which node had keys
Message 13 of 14
I'm sorry, still having trouble finding the COG control group. I dont see an image attached to your comment
Message 14 of 14
Hi
check the image. as per image check ur scene file outliner
