problem with retargeting animation using HIK
Message 1 of 10
So I'm having what seems like a bug happening in 2018 that I wasn't having before. I went back and tested it out on a rig that was working fine with it and it had the same problem. Video attached.
Replies (9)
Message 2 of 10
Anybody? has no one encountered this before!?
Message 3 of 10
tony.su
Autodesk Support
Autodesk Support
I need your two file to test. Could you upload your rig file and another rig with mocap data file?
Tony Su
Product Support
Message 4 of 10
here are the main rig file and one of the mocap files
Message 5 of 10
i can't seem to load the maya file
Message 6 of 10
tony.su
Autodesk Support
Autodesk Support
You can zip your file and upload. I need two files.
Tony Su
Product Support
Message 7 of 10
sorry for the delay here is a zip file
Message 8 of 10
I've had the same problem a few times before. Try referencing your animation in, instead of importing it into the scene.
Message 9 of 10
that actually seems to be working!
Message 10 of 10
Awesome 🙂 please mark the thread as solved, in case others have the same problem
