Paint weights not displaying
supafish
supafish
Apologies in advance for what is probably a real noob question( at least part of me hopes it is). I have built a rig and  skin bound it . The rig works but when i go in to adjust the skin weights the joints dont come up in the paint weights dialog box and the model does not display the customary black and white/ color areas of influence. The model has had its history deleted and was worked on in both obj and fbx formats, Even applied a Maya auto-rig to the geo (which works) but still cant see any areas of joint influence. Also do not see any influence when selecting specific edges/verts in the component editor under the smooth skin menu.Please refer to the screen shots Again apologies for the rookie question and any time answering this question is appreciated.
jmreinhart
Could you share the scene file?
supafish
Thanks jmreinhart for sowing interest towards my predicament I can appreciate your time is  precious . Please find the requested file attached. Should you have any further queries please do not hesitate to contact me.Regards supaocto.
jmreinhart
Your mesh is not being deformed by a skinCluster, it's being deformed by a promity wrap. That's why there are no skinweights to paint.
supafish
Thanks again jmreinhart for coming to my rescue as your solution worked, Hope i didn't waste a lot of your time you are a legend.
jmreinhart
I'm glad it worked for you. Don't forget to mark the question as solved 🙂
