Missing inputs for closestPointOnMesh node in the Node Editor
Hello again Maya forum. I've recently tried learning to use the Node Editor for advanced rigging and it seems intuitive enough, however for some reason I can't create a closestPointOnMesh node that has inputs.
Here is the example I am trying to replicate:
and here is me trying to do the same thing. I pressed TAB, entered in closestPointOnMesh and created a node for it, but even expanded all the way, there are no inputs.
I tried other nodes, like an OrientConstraint and it has inputs, it seems the one node I want to use doesn't create inputs when created in the Node Editor. I noticed I CAN get inputs if I select a mesh, and give it a closest point on mesh constraint from the constrain menu, but I'm wanting to connect a locator shape to it, and then from it to a follicle, so I have no need to involve a mesh at all. Plus it creates cpConstraintIn and cpConstraintPos in the outliner which are apparently not used in the example I'm following. Am I doing something wrong, or is there a way to utilize the node in the node editor?
stephenkmann
right click on the closestPointOnMesh node.
and choose "show all inputs" from the menu
hth
=s
Thank you for your help! I thought expanding the node fully would be enough to reveal all the attributes but I guess not. Your solution worked. Smiley Happy
