maya's teeth working
smyungPV34A
Message 1 of 16
smyungPV34A
I got questions about rigging teeth.
If I move the mouth with shape editor, the teeth doesn't follow the mouth's directions.
Moreover, if I rotate the character's god control into rotate x -90, activates the shape editor, the teeth goes into wrong directions.
What are these reasons and how do I fix them?
Please give me very, very specific answers.2018-12-29.png2018-12-29 (3).png2018-12-29 (5).png
Replies (15)
Message 2 of 16
I think its hierarchy issues.
Go to bindpose, removes the skin in teeth geomentry,  then bind the teeth geomentry.
Still the problem consist, delete  the history of teeth geo , then connect the BlendShape and the do the skin bind.
I think it will work.
thanks
Message 3 of 16
smyungPV34A
Hello, thanks for your reply.
But in those two solutions, where and how do I get into bindpose, remove skin?
and bind the teeth geometry with what? Object hierarchy, joint hierarchy or selected joints?
Moreover, how do I connect the blendshape and which skin options do I need to bind with?
Can you please send with me some images or somethint??
I’m sorry if I feel like I’m urging you, but I’m a beginner.
Message 4 of 16
smyungPV34A
May I send you the work, so you can see what the problem is, please??
Message 5 of 16
ok. send me in my mail. [email protected]
I will do my best.
Message 6 of 16
mspeer
Hi!
Please don't post private data here in the forum (like your email address) to prevent abuse.
Use Private Message instead.
Message 7 of 16
ok.
Zip your scene file and upload here, we will see
Message 8 of 16
smyungPV34A
Ok.Here it is.
I made the motions in it, but don't mind of it.
Thank you for looking at it.
Message 9 of 16
smyungPV34A
Moreover, I’m sorry if I feel like urging it, but I would like to see it as a video of how you fix it.
Can you please make video of how you find the problems, please??
Message 10 of 16
hi
I attached your Character. please check.
Please correct the improper blendshapes.
Message 11 of 16
smyungPV34A
Thank you.
But by the way, the file is .rar.
Which format do I need to change and save it as?
Message 12 of 16
using WinRAR software  you  extract the file.
Message 13 of 16
mspeer
Hi!
To share files please use the most common, widespread and backwards compatible format.
For compressed files this would be ZIP without any advanced compression options, or simply upload the files directly/uncompressed.
WinRAR can create ZIP files.
Message 14 of 16
smyungPV34A
Really sorry, but I don’t know how to save it as winrar and it can’t be opened in my window 10 notebook.
Can you just send it as just a zip file, please?
Message 15 of 16
smyungPV34A
Actually, I think I can open it.
Thank you.
Message 16 of 16
smyungPV34A
It works really well.
Thank you so much for your help!
