Maya rigging head problem
gutierrezezequiel774
Observer Observer
Observer
Observer
Hello, I was trying to rig the head but I had an issue where I had finally constrained the head to the head joint, but when I did that the neck joint rotates backwards then head rotates forwards Im not sure why its doing this.
mcw0
Maybe check your local rotation axeses of the neck and head joints.  Make sure they are oriented the same if you want the same behavior.
Observer
Observer
oh thanks Ill try that
