Maya is not showing
Maya is not showing
Maya is not showing
sir
I install Maya 2018 from Autodesk website.but after installation it not showing nowhere not in panel no desktop icon or not in start menu.but when I going to install again it shows that Maya is installed already.
in cpanel Autodesk network license manager is showing but I can't uninstall it showes only two option repair or change. when I click on repair it just opens up a dialog box suddenly close it.
mspeer
Hi!
Check for maya.exe in the install folder and start Maya from there.
If it does not work or you are unsure, then do a clean uninstall of Maya and all components
and download the installer again. Don't use "Install Now" method, instead try one of the other download methods (i recommend "Browser Download" in this case).
