Maya graph editor key size
Hi I have Maya 2018 on my Windows 10 Surface Pro 4 and when I go into the graph editor to move points they are very small even when zoomed in and I can only select anything through drag select. I cannot just click on a point. I have tried switching to classic mode and reloading the editor and that did nothing. Does anyone have any ideas on how to fix this or is this just how it is on this laptop?
I don't know how scaling Keys,
but you can change display as like Maya Older version.
You can find menu Windows - Settings/Preference > Settings > Animation > Graph Editor > Graph Editor UI:Classic
and close graph editor window and re-open.
마야 2018 그래프 에디터에 보면 키 포인트가 너무 작아서 알아보기도 힘들고 편집하기가 상당히 까다로운데요
키 포인트 크기를 크게 조절하는 방법은 잘 모르겠지만
이전 버전 처럼 키 포인트가 분명하게 잘 보이게끔 하는 방법은 있습니다.
그래프 에디터 보기 방식을 클랙식(이전버전)으로 돌리는 겁니다.
위 메뉴를 따라 가서 설정해주면 됩니다.
그래프 에디터 창을 닫았다가 다시 열어야 반영이 됩니다.
Try this:
In graph editor, view > keys > always
stephenkmann
In your preferences go to the animation settings, there is a setting for graph editor key size
hth
-=s
https://www.youtube.com/channel/UC2jQHsCj-DBZOHwKGjzNGIw
