Maya default layout
Maya default layout
shmorgyg
Maya default layout
shmorgyg
Normally  the Maya default layout has the timeslider longer and the playback controls are to the far screen Right .
Currently my timeslider is bunched up and the playback controls are not in the corner- see attached pic.
Is there a way to return the layout to the way it was before without restoring to default setting? Or is this the new layout for 2018?
i attached some images to do the process. please follow.
shmorgyg
HI there- Thank you for replying- I'm not sure I understand your directions. - I tried them and I still have a layout problem - also I think I lost some tabs on the side. If you could be more specific with the directions...
Thank you again!
mspeer
Hi!
Windows -> Workspaces -> Reset ...
shmorgyg
Thank you!
