Maya crash when scrubbing in timeline!
Message 1 of 20
Maya 2017 crashes when I scrub through the timeline, I do have installed 3rd or 4th update. I end up with ending the program by ctrl+alt+delete.
Replies (19)
Message 2 of 20
gautham.chandran47
This could be the evaluation mode problem. Try changing it to "DG" or if its DG then to "Parallel". I had the same issue when I was starting Maya 2017 for the first time.Screenshot (236).png
Hope it helps.
Goutham Chandran
Cinematic Animator | Rockstar Games
Linkedin | Instagram | Facebook
Message 3 of 20
That worked. Changed to DG.
Message 4 of 20
gautham.chandran47
Great
Goutham Chandran
Message 5 of 20
YOU'RE A LIFESAVER. THANK YOU SO MUCH!
Message 6 of 20
gautham.chandran47
ha ha , happy to help. 🙂
Goutham Chandran
Message 7 of 20
nFighter
Is it possible to fix the Parallel evaluation crash somehow or it's a maya bug and we need to wait for an update?
My timeline simply stop to work when it's more than 3-4 clips imported in time editor and seems like parallel evaluation is the only option that could help but it's crashing all the time. So there is no way for me to use time editor at all 😞
Message 8 of 20
gautham.chandran47
I think there is something with the assets we're using. I used to have this problem before. I was using an old Rig. But after a few days I re-rigged the character with Maya 2017 and I have no problems while using Parallel Evaluation now.
Goutham Chandran
Message 9 of 20
nFighter
I believe all my assets are Maya's 2018 default HumanIK rig, but I also remember when it works without crash. So I'll try to figure it out, thanks!
Message 10 of 20
gautham.chandran47
Happy to help. All the best for the project Smiley Happy
Goutham Chandran
Message 11 of 20
nFighter
OK, guys, I spent a lot of time searching and seems like finally I found something!
Parallel evolution crashed when you have a root bone as a parent of hip bone. But when you take out your skeleton hierarchy and keep it just near the root bone - it works. I test couple of my old problematic scenes on different laptops and it works! Maybe it's not the only reason to crash, but this trick help me and I hope it could help someone else.
Message 12 of 20
Please file a detailed step by step report of how to replicate this behavior. Also please include information about your system, such as hardware, OS, Maya version, and other installed software.
http://download.autodesk.com/us/support/report_a_bug.html?SelProduct=Maya
If your issue is resolved at any point, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 13 of 20
nFighter
Already submitted!  Cat Wink
But unfortunately, I can't mark my own post as a solution here. Let's hope it will help someone and they will mark it.
Message 14 of 20
You are the bomb. Thank you!
Message 15 of 20
A student panicking 2 days before her exam is endlessly thankful to you!
Message 16 of 20
gautham.chandran47
Happy to help Smiley Very Happy , and all the best for your exam Smiley Happy
Goutham Chandran
Message 17 of 20
gautham.chandran47
Ha ha Smiley Very Happy thank you.
Goutham Chandran
Message 18 of 20
YOU ARE A GOD! Thank you so much for this. I've just spend the whole day troubleshooting why Maya crashes all the time. Great job!
Message 19 of 20
gautham.chandran47
Thank you, Glad I could help Smiley Very Happy
Goutham Chandran
Message 20 of 20
Non of solution here didn't work for me, after all possible testings i manually backup and delete each file in maya\2019\prefs\ and my problem was in file userPrefs.mel, simple delete that file, close maya and start again, maya will create new userPrefs.mel and everything work justine. Hope this will work for someone too.
