Maya 2022 Graph editor
curlanimation
curlanimation
Somehow I changed all my graph lines to pink in the editor, anyone know how i can change them back? Thanks
Kahylan
Hi!
In the Grapheditor, select the pink curves. Edit -> Remove Curve Color
Your problem was likely caused by accidentally hitting "Change Curve Color" which has the default value of Pink.
I hope it helps!
curlanimation
Thanks for the response, I understand how I did it,But how do I undo or fixit?
Thank you,
Brian
Kahylan
Just select the curves and run the command "Edit->Remove Curve Color" highlighted in the picture I attached in the first response
curlanimation
Thanks so much, that did it.
