Maya 2022 Euler Filter Crash
maddiembrennan
Observer Observer
maddiembrennan
Observer
Observer
I've been trying to fix a part of my animation with the Euler filter to avoid gimbal lock.
The problem is, every time I click the button to activate the filter Maya crashes.
Is this a new issue with the 2022 version? The weird thing is it doesn't even take me to the page claiming that it crashed, it just sits there with the "circle of death" and I can't do anything until I force it to quit.
But is there anyway to fix this issue?
kelly_hynes
Please provide more details for this crash.  I did a test with 2022 and the Euler filter and did not crash.
Do you have a scene file I can test with?  What OS?  Does it crash with a simple scene? What are the exact reproduction steps?
Kelly
Kelly Hynes
Manager, Software QA Engineering
Installation & Licensing forums | Contact product support | Autodesk AREA
I have the same issue. Euler filter causes freezing/crashing with the "circle of death" and have to end task to force it to quit. My drivers and graphic card are up to date.
What is the solution?
sdonU453R
Iam also facing same issue someimes, Euler filter causes freezing/crashing. Can somebody assist me with this problem?
CHARLESFRNC1
On Reddit, I found the answer to my version of this issue. Thanks MoodyPurple!
Solution:
"Try Windows->Settings/Preferences-> Preferences->Animation switch Evaluation mode from Parallel to DG" - MoodyPurple on Reddit
