Mash "Time" Node
Mash "Time" Node
mortze55
Observer Observer
Mash "Time" Node
mortze55
Observer
Observer
I prefer to prevent, I use google trad because my English is zero.
I come to you because I have a problem when I want to animate a rain. In the MESH, the "Time" option is not available (it is grayed out) like you see in the screen, and the same for the "Color" option, do you have any idea why I can't use it?
Thanks very much !
dinofiguera
I'm not quite sure why your time node is grayed out, but why don't you simply create a vertical curve from the sky to the ground and use the curve node to animate the rain?
If you play around with your curve node attributes you can have a nice rain in a few clicks.
D
