MASH - possible to combine "Delay" and "Spring"?
BenediZ
BenediZ
I was testing MASH with its Delay and Spring nodes.
Objects should come one by one into the scene ("Delay" did influence a Mash transform)
and then jiggle a bit with Spring node, when reaching their final position.
This worked fine without "Delay".
But as soon as Delay is activated, the Spring node had no more effect.
Any thoughts about this?
mspeer
Hi!
Here it works.
Please make sure to add the Spring node as last node.
If you add the Spring node before the Delay node it will not work as expected.
BenediZ
Thanks, I will test this next time.
I did not know, that there is an order in MASH.
Is it possible to edit the order in the Node editor?
mspeer
Hi!
You can change the order in Node Editor, but it's easier to do in MASH Editor.
