Making a joint group to change its pivot point
consrojo
consrojo
Hello, im in a rigging process, right now im making joint group to change the place where the joint could have some extra manipulation, but when i create the group i cannot use the manipulator controls, as you can see in the images, 1 without the group created, 2 with the group set(im seeing Anticgi videos, part 7, reverse foot, 14:07).
any ideas?
tks in advance
ShinyShadow41
That's because that joint is being constrained, so a parent node(in this case group) can't move it.
consrojo
thats true, gonna see why i have that one constrained and yes delete the constraint node, the group setting works, tks shinyshadow41.
