Is there a MEL command to select clusterHandles by type???
rflack
rflack
I can select clusters, sure! Can't seem to find a way to select all cluster Handles in a scene! 😕
Thanks.
osidedan
For a MEL command, this should work:
$allClusters = `ls -exactType "cluster"`;
select -cl;
for($cluster in $allClusters)
    $clusterTransform = `listConnections -t transform $cluster`;
    select -add $clusterTransform;
Another option is to go Select>All by Type>Clusters, but if you need it MEL based, the above should work!
rflack
It's a work of art, thanks! 🙂
osidedan
You're welcome, I'm glad it worked!
