Is it possible to make your own PaintFX brush?
bluebunny1410
Message 1 of 12
bluebunny1410
Is it possible to make your own PaintFX brush? I've tried searching the net several times but I can't seem to find one that gives any clues. Sorry if there's already a post regarding this. If any, please send them over to me. Thanks in advance.
Replies (11)
Message 2 of 12
stephenkmann
At the bottom of the generate menu, there is a menu Item for "save brush preset"
using that tool you can save your brush settings to the current shelf or visor. and there is even a way to make an icon
if I've already lost you,  you can edit and alter the paintFx stroke in a billion ways.. there are hundreds of settings and sliders..  Start with a brush that is similar to what you want, and then edit it.. and then go back to "save brush preset" to save it for next usage.
hth
-=s
Message 3 of 12
bluebunny1410
Yeah I get your point. But what I'm trying to say is if you can change the actual geometry generated by the stroke. Like for instance, the leaves that are popping up with the vines stroke. I want to replace them with a specific geometry instead of the current one. Is it possible? Thanks for the reply btw.
Message 4 of 12
stephenkmann
All the brushes you find in the visor/browser are created from the exact same node.
You can create all sorts of different output geo. so the same options that create all the different kinds of leaves. can also create things like windmills , teapots, and flags waving in the wind .
  It isn't pulling in outside geo, but generating it .
so, while you can't ( afaik) import hand made geo into the system,  you can create some pretty complex-ish geo output from the paintFX system .
hth
-=s
Message 5 of 12
bluebunny1410
So in other words, we're stuck with the geos that are in the Visor?
Message 6 of 12
stephenkmann
not exactly,
   In other words. the brush can be edited to create lots of different geo.
you just have to think procedurally, and bend it to your will to create the geometry you want.
Message 7 of 12
bluebunny1410
How? The tutorials I see out there just seem cover the only basic settings.
Message 8 of 12
stephenkmann
not sure what you mean by "basic settings"
but after your draw with a brush,  open up the attribute editor, and look at all the settings for the "brush" and you'll see how it's created,     There are  a lot of settings, but they all build off each other.   so there isn't much difference
between twigs, branches, stems, and leaves.  they all have basically the same  attributes. you just change them differently.
if you open up "tubes" and check under "growth" you'll see  the different "branching" you can create.
best thing to do, is to look at something simple, like sunflower. and open up all the tabs to see how it was created, and then check something like woodChess, and see how it was created.
if you use "help" for brushes. you'll get an idea of the possible channels for it
https://help.autodesk.com/view/MAYAUL/2020/ENU/index.html?contextId=NODES-BRUSH
however , with all that said, maybe whatever it is you need to do might be easier to accomplish with MASH or xgen
hth
-=s
Message 9 of 12
bluebunny1410
Like this for example. Can I change the bud that it generates for instance? I just wanted it to be more stylized or something. Is it possible?
And yeah, MASH offers great creative ideas. Just trying out the PaintFX tool since it also has some nice tweaks that I find quite interesting.
Message 10 of 12
stephenkmann
hmm.
looks like buds are just a scale on the end of the tube geo..
Message 11 of 12
bluebunny1410
It is. And I want it to look better than that if there's a way. Same with the other leaves. Some look too 'squarish'. Doesn't look very natural.
Message 12 of 12
stephenkmann
yup,
depending on your needs , something like mash or xgen might work better.
or even just pushing lots of geo
good luck
-=s
