ik spline problem
ik spline problem
Message 1 of 18
ik spline problem
here joins from one rig and my joins (with red dots)here joins from one rig and my joins (with red dots)
I want to make ik spline curve work more "stronger" like red joins but I don't know how I have seen in nodes but this curve just scale some joins for the stretch, tried copying attributes in curve's and in ik handles. tried to find help in browse but could not, and sorry for my English if I made somewhere mistakes and for image qualify too.
Replies (17)
Message 2 of 18
jmreinhart
The result you want is for the spline joints to line up with the regular joints?
If that's the case you'll need to make sure that the last point of the curve your spline joints are attached to is attached to your ankle joint.
Message 3 of 18
Okay,but how i can do that?
Message 4 of 18
jmreinhart
Is the curve driven with a skinScluster? If so, you can select the last point of the curve, go to the component editor and check which joint it is being influenced by.
Message 5 of 18
Well i i check it when i back to home from shop
Message 6 of 18
Message 7 of 18
jmreinhart
Got to the smooth skins tab
Message 8 of 18
herehere
Message 9 of 18
jmreinhart
is pasted_joint3 your ankle joint?
Message 10 of 18
yep!
Message 11 of 18
jmreinhart
In the neutral pose is that last point of the curve in the same position as the ankle joint?
Message 12 of 18
I think no,when i set 0 in slider last point moves to center of the grid(where i have xyz moving thing).
Message 13 of 18
jmreinhart
You need to move it to the ankle
Message 14 of 18
good i donegood i done
Message 15 of 18
jmreinhart
And that should give  you the result you want ,yes?
Message 16 of 18
no, it's moving same.
Message 17 of 18
jmreinhart
could you send the file or a video of it moving?
Message 18 of 18
