I press s but It can`t set key frame
Hello I`m MAYA beginner
I want to make animation that yellow ball move
so I try move yellow ball and press S but It doesn`t work
I have massage like this
// Warning: file: C:/Program Files/Autodesk/Maya2019/scripts/others/doSetKeyframeArgList.mel line 632: Current manipulator and active objects have no keyable attributes, or animation layers are present and the BaseAnimation bar is not selected or locked.
I know yellow ball is locked I don`t know how to unlock
hamsterHamster
You have all transform channels greyed out, which means they are Locked. And those might be locked for a reason - the ball is rigged. Try to move some of the curve shapes (triangle, rings).. I believe you should animate those instead.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
