I keep getting an error message about lookdevx.
Hello, I'm a student who is working on an animation graduation work.
I'm currently in the middle of a rigging process, and when I right-click on the joint or Nurbs curve, the following error messages appear. (There was no problem when I chose mesh.)
Clearing and reloading Maya altogether does not fix the problem by modifying the prefs file name and opening Maya again.
Actually, there is no problem working on it now, but I am worried that it will be a problem later because the error message appears in red.
Is it okay if I leave it and proceed with the work?
the error messages :
select -r L_leg_ctrl ;
// Error: file: /Applications/Autodesk/lookdevx/maya2025/1.6.0/lookdevx/scripts/LookdevXViewportMenu.mel line 32: No object matches name: L_leg_ctrlShape.surfaceShader
or
select -r joint1 ;
// Error: file: /Applications/Autodesk/lookdevx/maya2025/1.6.0/lookdevx/scripts/LookdevXViewportMenu.mel line 32: No object matches name: joint1.surfaceShader
PS: Please understand that the expression may not be smooth using a translator.
