Announcements
How to zero out Quick Rig controllers?
saralie.wagstrom
saralie.wagstrom
I rigged a character using Mayas Quick rig system, and I now noticed that the controllers aren't zeroed out and contain transform values.
I would like to have controllers without any values to to make the animation process easier.
I've tried to make my own controllers but I can't seem to make it affect the rig.
Is there a way to make controllers for the Quick Rig that have 0 in transform and rotation?
DanPym
I've had the same question for some time....it's incredible that no one can aswer this question, even trying to find an answer on the web is impossible! Did u figure it out?
stephenkmann
in the HIK UI. there is a little button on the far right that looks like an orange bathroom symbol.
It is the reset control button. .
select the controls you want to set to default, and press the button
 hth
-=s
DanPym
it resets the pose but doesn't zero out the values in Channel box for the selected controllers, so it doesn't work.
stephenkmann
for HIK ,, it never sets the channels to zero..
the rig controls, always carry values of where they are in world space.
you can "zero" them out.. in the sense of putting trans of 0 0 0 and rot of 0 0 0 , but that won't do anything.
Its one of the frustrating things about working with HIK
The controls are kinda like a live system.. so moving them. actually moves a whole bunch of stuff, and eventually the joints..
The system is always evaluating, and so the controls will show their WorldSpace location.
hth
-=s
vivekmandapeta007
import maya.cmds as cmds
def selectedtranslate(*args):
selected_joints = cmds.ls(selection=True, type='transform')
if selected_joints:
for joint in selected_joints:
cmds.setAttr(joint + '.translateX', 0)
cmds.setAttr(joint + '.translateY', 0)
cmds.setAttr(joint + '.translateZ', 0)
def selectedrotate(*args):
if selected_joints:
cmds.setAttr(joint + '.rotateX', 0)
cmds.setAttr(joint + '.rotateY', 0)
cmds.setAttr(joint + '.rotateZ', 0)
def undo(*args):
cmds.undo()
def redo(*args):
cmds.redo()
if True:
window = cmds.window(title='Controls ZERO')
tabs = cmds.tabLayout()
shelf = cmds.shelfLayout()
cmds.shelfButton(
annotation="Translate ZERO.",
image="text.png",
imageOverlayLabel="XYZ",
overlayLabelColor=(1, 1, .25),
command=selectedtranslate
cmds.shelfButton(
annotation="Rotation Zero",
image="SVGRefresh_200.png",
command=selectedrotate
cmds.shelfButton(
parent=shelf,
label="Undo",
annotation="Undo",
image="undo.png",
imageOverlayLabel="UNDO",
overlayLabelColor=(1, 1, .10),
command=undo
cmds.shelfButton(
parent=shelf,
label="Redo",
annotation="Redo",
image="redo.png",
imageOverlayLabel="REDO",
command=redo
cmds.tabLayout(tabs, edit=True, tabLabel=(shelf, 'Trns l Rota'))
cmds.showWindow(window)
else:
cmds.warning("No joints selected")
kiransai2216
Community Visitor
Community Visitor
while using this script it's giving an error like
else:
# Error: expected an indented block #
But i've tried selecting whole controls and individuals, nothing works
please help!
