- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
When I set up a key driven parameter (Animation set Key-Set Driven Key-Set), e.g. to make one attribute parameter drive the Rotate Z value of another, I set a range to limit the rotation in either direction.
e.g.:
I set Driving attribute: -25 and Rotate Z: -45. Hit Key.
I set Driving attribute: 25 and set Rotate Z: 45. Hit Key.
This works, but I would like to make the Driving Attribute parameter also limited to the range I set, i.e. -25 to 25, just for neatness and to show the animator the affecting range. Is there a method?
