How to create variable influence between two joints? (Except parenting)
Hello everyone! I have some experience of work in modeling and texturing, but rigging and animation is new for me. I know that we can parent one joint to another one, and it will translate, rotate and scale the same way as it's parent, but what if we need just a particular influence? For example if I move one joint on 4 meters left, second one moves the same way but only on 2 meter left, or I rotate first on on 30 degrees and second one rotates on 15 etc. Is there any ability to do that?
stephenkmann
You should be able to do what you want with a parent constraint.
each "master" into the constraint is weighted, and that can be adjusted
hth
-=s
