How to animate simulated cloth?
serenalagrotteria3H2CK
Observer Observer
Observer
Observer
I just learned how to simulate a cloth with ncloth and was surprised how easy it is. I recently modelled a bracelet and I want to create a small animation out of it: The bracelet has to be covered by the simulated cloth (needs to fully covers the bracelet) and then the cloth has to "slip" on the right side. So basically the cloth needs to change shape by each frame. Does anyone know how it works?
mcw0
You said the solution yourself.  You would simulate the cloth.  Use your bracelet as a collision object.  As for choreographing the slide to the right, you can use a transform constraint or a force.  The constraint will be easier.
Observer
Observer
Sweet, it worked! nconstaint is a true bless. Thank you for your help!
