How do I set up a rotation controller?
Maybe I'm looking for the wrong thing (at least by name) but I've seen them before where a controller allows the rotation of a specific part such as a knee but I can't find anything on how to do it.
So my problem (see attached) is that I want to set up a controller so I can rotate the back of the wing but can't figure out how. Is it as simple as adding more joints to the back of the wing or is there a better way?
Hey there, not 100% sure... but I feel what you're looking for is as simple as an Inverse kinematic function?
An IK is what you need to add and it'll create a locator, connect the controller to drive that locator and you're set. You will also need a controller at a good distance from the "elbow" and connect that controller to the IK locator you made and make a pole vector constraint!
Hope that truly helps you out! If you need any additional help in rigging from the very basics to more advanced techniques, I do have a 14+ hour course with over 120+ lectures that covers every single thing in rigging!
RIGGING COURSE
Thanks for the response, I'll try this out and let you know how it goes.
Thanks, that also allowed me to set up a knee bend when I lifted the leg which I didn't have prior.
