How can i do cycle aniation then stop them?
Connor_Dang
Connor_Dang
For example:
I do i bird flying with 3 key then loop them.
After that i want to stop this loop when the bird is standing at the end.
Do i able to do that?
Thanks for your help
instead of cycle you can copy the keys and copy upto what you want (Time). This will easy for this.
Connor_Dang
Hi thanks for your helps.
That gave a good result but i'm curious, is this a best way to do something like that?
Thanks again
AntWard
You could set your animation curves to cycle, so they will loop continuously. You then bake the cycle to the point where you need it to stop, and then animate after that.
Connor_Dang
Please, Can you explain in more detail how to do it?
Thank you for your help
hi
once you made cycle, then set the timing in time slider and select the keys in graph editor then go to bake simulation (pic 1)sa shown in pic.  then make the curves constant (pic  2). now the keys are baked and stopped to your set time.
Connor_Dang
That's helpful
Thank you very much 🙂
