Freeze transformations or other action
I have a noob question.
I have created a quick rig with skeleton and controllers.
After the quick rig is created all controlls have values on x,y,z
Is it possible to zero these controls in any way without the rig to "break".
Or is it another better way to to this without freezing transforms and get similar results?
mspeer
Hi!
A) Use Freeze Transformations (what's wrong with this?), or
B) group the controller and move the group.
gautham.chandran47
@mspeer is right. Grouping the controller and moving it is the ideal way to re position controllers.
Goutham Chandran
Cinematic Animator | Rockstar Games
Linkedin | Instagram | Facebook
I tried grouping the controller and moving it but the controller wont move or rotate with its parent.
The image shows how the object looks in maya before grouping
When i freeze transforms on the controller, the controls x,y,z is zeroed,
but when i move the controller just one mm, the values from before i froze pops back up on the object.
gautham.chandran47
Ohh, you were referring to Maya Quick Rig,,, Smiley Very Happy mybad, Its a HIK rig so you can't modify the controllers because they may seem like controllers but actually they are effecters. i'm afraid you can't modify those as you like. Smiley Sad I tried that before too.
Goutham Chandran
tony.su
Autodesk Support
Autodesk Support
Do you need more help?
Tony Su
Product Support
