Error: PushPop directory not created or not found - Game Export Maya 2017
Americi
Americi
Hi, I'm trying to use game export on my projects, to have an .fbx with multiple animations takes, but when I use it, i got this: "Error: PushPop directory not created or not found."
I've already searched in every where, tryed to to reinstall maya (more than once) and can't find a solution. Maybe someone of you guys can help me. If not with game export, with another way to export an fbx file with multiple animation takes.
By the way, I'm using Maya 2017 (ext. 4) and game export isn't working on all my projects.
Thanks!
Did you find a solution?
Americi
No 😞
However, I don't have this problem on Maya 2018.
Good luck!
I have this problem in both versions
I solved the problem. I've renamed my User name in Windows from "Человек" (Unicode) to "Human" (Latin alphabet) following instruction in website - remontka.pro .
As I saw the answer about renaming the username - I tried it myself. It worked.
Since my username was 'Jäckey' , I guess Maya couldn't understand the 'ä' or any type of special letter. (Correct me if I'm wrong)
I reinstalled windows (I know there are easier ways to change the usernamepath by creating a second user and so on). This time naming myself 'Jackey'. And it worked out fine!
If you don't want to install Windows again, just search for 'Change Userpath name', there are a lot of good step-by-step tutorials.
damnablefox
我已经解决这件事情。
根本原因是电脑用户名存在MAYA游戏导出器不支持的字符。
解决方法有两个:
一、更改电脑用户名
具体操作自行查找。本人不建议这样做,这个方法对电脑中其他应用存在隐患。
二、更改MAYA首选项存放路径。
1.打开系统环境变量,点击新建。
2.输入变量名:MAYA_APP_DIR
3.输入变量值:新创建文件夹路径或应包含Maya首选项的现有文件夹的路径。
4.单击确定保存。
5.启动maya,使用“游戏导出器”(Game Exporter)导出对象,并查看该功能是否起作用。
