Double key in the same frame (Graph Editor)
RocioGS1999
Message 1 of 9
RocioGS1999
Hey everyone, I'm doing a animation and I have a problem in the graph editor. Bassically It's creating 2 keys in the same frame and I don't know how to fix it and It's annoying to delete every key that is duplicated.
Somebody know how to fix it? Thanks!
Replies (8)
Message 2 of 9
jmreinhart
So to fix it. You do just need to deleted whichever key you don't want. Two things that could have caused it to happen is if you were moving keys in the graph editor and accidentally moved two keys onto the same frame. That can also happen if you accidentally move to a non-integer frame like frame 1.01 instead of frame 1, and created a key.
Message 3 of 9
RocioGS1999
Thank u so much! The problem was the second example u said.
Message 4 of 9
onliiaj
How do you solve it though? I think it's the 2nd option for me, "snapping" doesn't work because of "multiple keys", when I change positions and key them, the double key in the graph appears, don't know how to fix it, it's extremely annoying 😞
Message 5 of 9
jmreinhart
Delete the the duplicate you don't want, and snap the remaining one to an integer frame by clicking on the "snap horizontal button" on the graph editors tool bar.
Message 6 of 9
graph editor> edit > select unsnapped and delete. this will automatically delete multiple keys on the same frame.
Message 7 of 9
mtfacey
Community Visitor
Community Visitor
Literally saved my life! Thank you for this!
Message 8 of 9
suenoguajiro
Community Visitor
Community Visitor
That solved it! thanks a lot
Message 9 of 9
6521712087
real Accepted solution
