Do locators in maya 2020 not have local position or scale anymore?
nmendoza
nmendoza
I am using maya 2020 and noticed that when I put a locator in the scene I can't control local scale in the shapes section under the translate, rotate, scale, visibility, like I was able to in maya 2019.   Why is this?  I needed the local scale to make some bigger when I need to see them in a mess of objects in the scene.  And I don't want to scale it up if I need to parent something to it, but want it bigger to see in the scene.
mspeer
Hi!
I can't see any difference.
Here it works in Maya 2020.
nmendoza
Maybe these pics will help.
mspeer
Hi!
Try a reset of your preferences.
Rename the folder prefs in folder 2020 to something like prefs_backup, or to reset everything, the folder 2020 to 2020_backup (or even the maya folder to maya_backup). Maya creates new folders (don't copy preferences from previous Maya versions). Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
