Announcements
Disable MASH Dynamics node with keyframes
Hello everybody,
is there a possibility to disable the Dynamics Node in a MASH Network until a given Keyframe?
Thanks!
newtaov
I do this Keying MashDynamics>Velocity>Maximum Translation and Maximum Rotational from 100 to 0. A wide distance between Key 100 to Key 0 gives you a smooth transition between movement and freeze. The problem using this is that sometimes things stops in the middle of the air.
I'd like to have some feature that simply calm down all dynamics instead of freeze them.
