Control Axis(Gizmo) Rotates Negatively in Hierarchy Selection
Oladoyinbodaniel
Oladoyinbodaniel
Hi guys, whenever i select my leg joints hierarchically(entire chain), it rotates in the negative direction as to the direction I move my mouse towards. However, when a single chain is selected, it rotates the normal way(it follows the direction i move my mouse), how can i fix this, pleaseeee?
jarombrand
It's hard to tell from the images, but I think the issue might be because you have the last 2 joints in the chain oriented differently from the rest of joints. The first 3 joints have y pointing out the side of the chain, but on the last 2 joints y is pointing in different directions. If you select only the first 3 joints, they should rotate as expected because they are all oriented the same way. Hope that helps.
