Announcements
Constraints
Constraints
bayareadeck
Constraints
bayareadeck
Is this still the case ?:
Its been said that animating one constraint on and off can give you
unpredictable results and its better to animate between 2 or more constraints.
hamsterHamster
I haven't used animated single constraint for the projects, however, from what I have read here and Help, then the RestTranslate and RestRotate serves as internal second constraint, local space, where the object JUMPS once the weight is 0.0.
Just tried, tested, works as expected.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
