Cannot Combine Multiple Curves into single Object
Kagiso.leh0003
Observer Observer
Kagiso.leh0003
Observer
Observer
Hey Everyone.
So I'm having trouble combining two or more curves into one object. I did the whole parent -r -s thing after selecting the curveshapes but I keep getting an error message that appears that says, '// Error: line 1: Last argument must be a group.'. What do I do?
Kahylan
Hi!
This error means that you didn't have a correct selection when you ran the command.
Select the shapes you want to combine first, then select an empty group or the transform node of the last curve.
The order in which you select is important with this command, as it uses an ordered selection list to get its positional arguments.
I hope it helps!
