Can't seem to get Set Driver to Key correctly and work
I've been trying to figure out why the set key for the set driver won't work. I'm following a tutorial on how to make cartoon eyes and when it got to the part where I'm suppose to key the driver and the driven together, it doesn't actually work. The channel box shows a small little highlighted box next to the section where it's suppose to be key but it's not moving when I move the curve tool arrow I created.
What I'm trying to setWhat I'm trying to set
Set and key- highlightedSet and key- highlighted
Does not work. Highlighted Surface area (from first picture) is suppose to come out like an eyelid.Does not work. Highlighted Surface area (from first picture) is suppose to come out like an eyelid.
I created the half sphere from a Nurbs primitive.
ohhhh, the famous driven keys! haha, they're very tricky at first, but once you get used to them they're so much fun and useful!
Let me try my very best to explain how to go about it... actually as I'm typing this I'll make a screen record right now for you to better show the steps how to go about it! (:
Attached I have a screen recording that I just did a quick example in, also can send you the scene file just in case you want to further check it out! 🙂 it doesn't let me attach it here for some reason, I'm never able to do so and not quite sure yet, but I can email it if you'd like!
I actually have taught over 100+ students thus far rigging in Maya! I do have a 14+ hour course with over 120+ lessons.. I cover everythingggg in rigging for Maya, from the very basics to much more advanced techniques! 🙂 I will put the link to that below and you can check it out to see if you feel it might benefit you at all!
Maya Rigging Course
Thank you!
