Can't export FBX with animations attached to it
I've been trying to export Maya file as .FBX to unity with animations attached to the model but i can only Export the model but when import the same fbx model into Maya again i can see the rig animating without being attached to the rig, would be a great help if someone could help me with this
andreasng____
if you just want to export/import animation on control curves use "PAIE"
https://www.highend3d.com/maya/script/paie-for-maya
then select your control curves, export the animation, dont select skeleton or mesh.
Dont use FBX as a way to export/import animation. FBX is for one way traffic into a game engine or something else.
Thank you very much for responding but i wanna export both the mesh and animation as a single FBX to use in unity, i get the same issue as i do in maya,
only the camera will be animating but the mesh will stay still
andreasng____
if you want to use the animation in Unity here are some important notes:
Dont export control curves, they don't do anything other than affect the bones.
Use this Hierarchy:
Char
 -Mesh
 -Bones
Char Stuff
 -ControlCurves
 -Ik handles
When you want to export for unity, choose the Char and press export FBX. Make sure the FBX exporter bakes keys - and actually exports animation. See in the settings if it does. DO NOT export Char Stuff - it does not have anything to do with the actual character.
In unity you "need" a Char and then you need animations for that char.
So you will have files that look like this
Char
Char@IdleA
Char@IdleB
Char@RunA
Char@WalkA
etc etc
The Char file is your model, and unity will put anything form the same folder with a "@" in it as the characters animations.
Then via code or playmaker or whatever you can make the char use those "@" animations.
oh ohkay, thank you for your time. will surely try this method and  will probably update you with how the animation works and looks in the game 🙂
