Can't edit graph editor handles
Message 1 of 12
For some reason I can't edit the curve handles in the graph editor. When I try and select a keyframe, nothing happens.
Replies (11)
Message 2 of 12
The handle's are circles instead of triangles or squares
Message 3 of 12
Have you tried creating a new empty scene and see if it does the same thing? A screenshot would help.
Also, check if your animation channel is locked or something similar. Make sure the color is red.
Cheers,
Message 4 of 12
I'm attaching a recording. Thanks so much for replying, I was thinking nobody could help!
Message 5 of 12
Here is an attachment of the maya file.
Message 6 of 12
Off course!
So have you tried with an empty scene while animating a cube for example?
I'm using Maya 2019 so I might not get the same result than you. My keyframes are not even the same shape as you too.
Have you checked the channel you are animating to make sure it's not locked or something?
I can't see your maya file anywhere in your last message...
Message 7 of 12
I figured it out.
It's because your curve is handled in Quaternion right now so there's no handles.
You have to change the Curve mode by going Curve > Change Rotation Interp > Independent Euler
https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Maya-Ani...
This is from the documentation:
Key types
     Diamond key: non-weighted tangents
     Square key: weighted tangents
     Circle key: a key on a quaternion curve (no tangents)
    Hollow key: A new key with 'automatic' tangents. The key is filled when you adjust the tangents to show that it has been edited.
Message 8 of 12
Forums won't let me attach the file, so here is the google drive link:
Reacon
Message 9 of 12
Thank you so much for your help, you saved my life!!
Message 10 of 12
mona.tajiki
Community Visitor
Community Visitor
you are amazing .thanks a million 👍👍👍👍👍
Message 11 of 12
lewis_young1
Community Visitor
Community Visitor
I just want to say I actually love you.
Message 12 of 12
ablahaUZTMW
Community Visitor
Community Visitor
Bless your soul 😭 I know I’m 4 years late to the party but I was having this same issue
