Beginner problem with Keyframe and Inbetweens
I am using Maya 2020 and I'm following a tutorial on just moving an object, should be super easy. I set my first frame, go to my tenth frame and change the character a bit and set the frame. Auto key is on the little square is red. But all of the frames in between are static and look just like the first frame. Nothing changes until the 10th frame. Do I have a setting wrong somewhere? I thought the in between frames were supposed to fill in automatically but something's not right. Please help!
gautham.chandran47
* Check if the controller you were animating actually deform the model. Just move the controller around to see.
* Check if the values of the modified controller is changing from the 1st frame and 10th frame.
* Try Drag and selecting the keys from timeline and changing the interpolation to Auto.
Hope this helps you to spot the issue.
Goutham Chandran
Cinematic Animator | Rockstar Games
Linkedin | Instagram | Facebook
Thanks for writing! It actually was a setting in the graph editor. It's all moving along now. 🙂
ryannp
Community Visitor
Community Visitor
Hi there, I am having the same problem here. What setting in the graph editor that you change to make it animate? Taking me ages and I can't find the setting. Thanks
