Animation not rendering properly
reniferziolo
reniferziolo
Hello everyone,
Recently I started to have this very serious issue, that is animation not rendering how it is in the viewport.
I am  confident that it's not a broken file issue as I sent it to someone and it rendered just fine. It depends on the scene but most common are:
animation not fully rendering- for example only one eye blinks,
-wrong frame goes to the render engine (  maya standard, arnold an vr-ray only hardware works fine) that is it should be showing frame 26  in the ipr but it picks at random
-animationn ot rendering at all- all frame are one frame rendered as a sequence - happended to the aniamiton mentor rig- rendered just fine on other machine
Only soultion I've got is baking everything but it is a workaround. some screenshots to illsutrate the issue:
Which version of maya you are using?  set the animation settings   in DG Mode. then try to render.
reniferziolo
I had no idea this existed. Will check it out.
reniferziolo
The issue was solved after updating the Maya to 2019, thanks for the suggestion though.
thanks
