Animation Moves Unpredictably Whenever Keyframes Are Changed
E_Student
Observer Observer
E_Student
Observer
Observer
I am working on my first loop animation in Maya. The model and rig were provided by my school. I animated a basic spin animation, but now whenever I make changes to the keyframes, the animation in between moves unpredictably. Adding, removing, scaling, moving, or updating an existing keyframe (even something as small as turning the head a little) will cause this. This happens if I try to work off the graph editor, too, but I want to work off the timeline for now if I can. The only fix I have found so far is to save the file after I make a change and reopen it. This seems to refresh the timeline and the animation runs as it should, but obviously, this is a very difficult way to animate having to save and open for every single change. I need to be able to animate and make changes without it spazzing out.
I tried the live chat option and I was advised to uninstall and reinstall Maya. (this caused a whole other issue where I could no longer open the software, but this has been fixed now.) So, I definitely have the latest Maya and everything should be refreshed, but I am still having the animation issue.
If anyone knows what might be going on or how to fix it, please let me know. I appreciate any advice.
I unfortunately cannot share the file because it is far too large for the dropbox. I am attaching a video of me recreating the issue. It plays normally first, but when I make any changes such as moving or updating a keyframe, the animation spazzes out.
stephaniebellgardt
Do you have caching turned on in the timeline? That will sometimes cause animation to spazz out and can be fixed either by toggling it off/on again, or just leaving it off.
This particular issue seems weird even for caching, but that was the first thought I had.
E_Student
Observer
Observer
It was off. I tried toggling it but it did not seem to change anything. I do have a suspicion it has something to do with the model being rotated around though. I was able to use my increment save and reopen trick to get the project done, but I will keep this open for the sake of others who may run into this issue.
