Animation layers - merge layers not working
BenediZ
BenediZ
When I merge animation layers with "delete baked layers" the layers still stay there.
Just another new layer comes.
When I "delete empty layers" none of the layers gets deleted, so the Animation layers just become more crowded.
When I deleted preferences userPrefs and menuSetPrefs nothing has changed.
startstartcommand "merge selected layers"command "merge selected layers"resultresult
sureshbabukollipaka
Community Visitor
Community Visitor
Facing same issue in 2020.4
filip.masiulewicz7CQLH
Same issue in 2022.4
rajivkar97
Observer
Observer
So.. Something that worked for me was that, i tried merging the layers separately instead of selecting all of them at once. Most of the time, this issue is caused by only one of the layers being partly corrupted.
A workaround that is merging the layers separately and finding out the corrupted layer then just duplicate it (delete the original layer) and merge it.
Also, it helps to keep the merged layer at the top till you go to the base animation layer where you can select the option to keep the merged layer in the bottom.
