Message 1 of 15
09:21 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
see file attached. I'm just trying to get this tree to move from one end to the other, as well as scale from 0 to 1. I will modify/center pivot, move the pivot to the bottom of the group and set up the animation. Fine Then I do a few more groups, or trees in this case. This will work for a while then break. Every time the tree will scale and get stuck on around .1 on the x, even though the channel editor and graph editor say nothing's wrong. I've tried freezing transformations, resetting transformations (which required me resetting the center point as in the sample supplied), but when I reset transormations, you will see in the sample supplied that the center point has now moved back to 0, and even thought it has, you will see when you advance 10 frames that something very messed up happens, where the tree grows from the middle and goes to the end point. None this make sense and I'm fairly certain I've cleared out just about anything that could be causing the issue. I also tried parenting all this to a locator and the same thing happens. I sure hope there's a solution to this. Dave
