Advanced skeleton face rig build issue
zjeanzheng
zjeanzheng
Hi, I'm trying to build an advanced face but once I get to the eyelid step, I get the error 23463: Head_M is not an influence object for this skin. I'm not sure if the order of my joints is right in the outliner.
If anyone knows what could be the issue, please let me know. Thanks!
Baboonian
Yep, you should bind all geos to Head_M joint. Or choose another one whichever you wish.
zjeanzheng
I tried binding the eyelid geos to the head_m joint, it says they are already binded to the skincluster. Do you know where I can find the skincluster and add the joint into it?
Baboonian
Press "delete history", then bind.
No, look, you need to bind everything head geometry to one joint
zjeanzheng
thanks a lot, I figured it out now
