Announcements
Advance Skeleton/Maya Error when rigging Ik
himinglaeva47
himinglaeva47
Hi, Im running into these errors when using advanced skeleton and trying to rig my wings with IK.
If I remove the IK Wing setup the errors disappear.
Any help would be greatly appreciated.
Edit: This Error is coming from the graph editor due to something going on with my reference. I tried what I found in searches to fix the problem but none of them worked for me.
// Updated Orientations
// Error: file: C:/Program Files/Autodesk/Maya2024/scripts/others/showEditor.mel line 2966: nodeType: No object or UFE path string matches name ''.
// ReBuild Complete
himinglaeva47
Edit: Its from the Ik Chain, its got me bouncing all over. I got the error to disappear changed the joint labeling and it popped back up. EEEK!
Ok, So after joint labeling the Ik and rebuilding to get the error I deleted unused nodes from Graph Editor and reloaded my reference, then closed and reopened the the scene and the error disappears. I dont know if this is a solution but the errors are gone. Sceeech!
