Announcements
Added a New Camera Not showing Animation.
I was working on a cartoon dog and things were going well, I decided to create a new camera that I was going to animate to go in a circle around my animation, however when I did, I could no longer scrub through it and play blasting it shows a blank screen. It worked up until I created the new camera and key framed it.
Any ideas how to fix it?
jordan.giboney
Autodesk Support
Autodesk Support
Hi @Anonymous
Thanks for posting!
When you go back to your original camera (not the one you created after your animation), is your animation still there? Can you still scrub through it? When you select a control on your rig, can you still see the key frames in the time slider?
Are your rig attributes locked? If you select a control and look at your Channel Box, are any of your attributes a different color (ie, brown, dark blue/gray, yellow, etc)?
If you'd like to send me your scene I would be happy to take a look at it 🙂
Thanks again! Looking forward to hearing back from you soon.
Jordan Giboney
Technical Solutions Engineer | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
jordan.giboney
Autodesk Support
Autodesk Support
Hi @Anonymous
I just wanted to check in and see how things were going! Were you able to get your animation working again with your new camera?
Let me know if I can answer any questions for you 🙂 I am happy to help!
Jordan Giboney
