[2018.1] Can't delete separated keys
Message 1 of 10
I'm having an issue with keys in Maya 2018.1. The thing is simple: I can't delete a rotation key from just one axis, instead, Maya deletes all the keys in the other axes. For example, if I want to delete a rotation key from X axis, I simply go to the Graph Editor, select the axis, select the key and press delete. Then, the keys from Z and Y axes are gone too.
I've tried using de Dope Sheet too and got the same result.
It's really anoing... anyone knows what's hapenning here?
Thanks!
Replies (9)
Message 2 of 10
mspeer
Hi!
Try a reset of your preferences.
Rename the folder prefs in folder 2018 to something like prefs_backup, or to reset everything, the folder 2018 to 2018_backup (or even the maya folder to maya_backup). Maya creates new folders (don't copy preferences from previous Maya versions). Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
If this doesn't help please upload a scene-file showing the problem.
Message 3 of 10
That didn't solve the problem, sorry 😞
I can't upload the scene because it's from a client.
Message 4 of 10
gautham.chandran47
In that case try braking the conncection.
For example, if you want to delete a rotation key from X axis,
♦ Select the controller,
♦ go to channel box and highlight rotation X,
♦ right click on the highlighted channel ( rotate X ) and choose break connection.
Hope this helps.
Goutham Chandran
Cinematic Animator | Rockstar Games
Linkedin | Instagram | Facebook
Message 5 of 10
Yes, that works, but it deletes all the keys, what I need is to delete just one key in one frame keeping the others.
Thanks btw
Message 6 of 10
andreasng____
DONT delete your prefs.
Change the rotation interpretation!
Graph-Editor/Curves/Change Rotation Interp/Independent!
 change_rot_interpret
I suspect maya for having a hotkey somewhere that does this to us. And we,,,, NEVER,,,, want it to be like that.
Message 7 of 10
bugsy5241
Community Visitor
Community Visitor
Sweet mother, thanks for this solution.  This....."feature"?  has been driving me insane for a while now.
Message 8 of 10
covitavelar
Community Visitor
Community Visitor
You saved my sanity
Message 9 of 10
AndreasPD
Community Visitor
Community Visitor
yes this is quite insane!
Message 10 of 10
gyver_gabriel
Community Visitor
Community Visitor
omg WHY this option exists?? doesnt make any sense!!!! thank you for the help
