2017/1/19:20:04:29 BIGLI LAPTOP-4GQDO8IL === Setup started on LAPTOP-4GQDO8IL by BIGLI ===
2017/1/19:20:04:29 BIGLI LAPTOP-4GQDO8IL Path_Length: 148
2017/1/19:20:04:29 BIGLI LAPTOP-4GQDO8IL Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_zh-CN
2017/1/19:20:04:29 BIGLI LAPTOP-4GQDO8IL Launch
2017/1/19:20:04:29 BIGLI LAPTOP-4GQDO8IL CommandLine /PK 128G1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_z...
2017/1/19:20:04:29 BIGLI LAPTOP-4GQDO8IL Current Directory C:\Users\BIGLI\AppData\Local\Temp\_AIEF49.tmp
2017/1/19:20:47:42 BIGLI LAPTOP-4GQDO8IL === Setup ended ===
2017/1/19:20:04:30 BIGLI LAPTOP-4GQDO8IL === Setup started on LAPTOP-4GQDO8IL by BIGLI ===
2017/1/19:20:04:30 BIGLI LAPTOP-4GQDO8IL Path_Length: 148
2017/1/19:20:04:30 BIGLI LAPTOP-4GQDO8IL Current Directory C:\Users\BIGLI\AppData\Local\Temp\_AIEF49.tmp
2017/1/19:20:04:30 BIGLI LAPTOP-4GQDO8IL Launch
2017/1/19:20:04:53 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:05:14 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:05:35 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:05:56 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:06:17 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:06:38 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:06:59 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:07:20 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:07:41 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:08:02 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:08:23 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:08:45 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:09:06 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:09:27 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:09:48 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:10:09 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:10:30 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:10:51 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:11:12 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:11:33 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:11:54 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:12:15 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:12:36 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:12:57 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:13:18 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:13:39 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:14:00 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:14:21 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:14:42 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:15:03 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:15:24 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:15:45 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:16:06 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:16:27 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:16:48 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:17:09 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:17:30 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:17:51 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:18:12 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:18:33 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:18:54 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:19:15 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:19:36 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:19:58 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:20:19 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:20:40 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:21:01 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:21:22 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:21:43 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:22:04 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:22:25 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:22:46 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:23:07 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:23:28 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:23:49 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:24:10 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:24:31 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:24:52 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:25:13 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:25:34 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:25:55 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:26:16 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:26:37 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:26:58 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:27:20 BIGLI LAPTOP-4GQDO8IL Download Error SETUP_CONFIG 代理需要验证 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:27:23 BIGLI LAPTOP-4GQDO8IL Download Play SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:47:42 BIGLI LAPTOP-4GQDO8IL Download Complete SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:20:47:42 BIGLI LAPTOP-4GQDO8IL PageOpen LaunchDialog
2017/1/19:20:50:48 BIGLI LAPTOP-4GQDO8IL PageOpen LicenseDialog
2017/1/19:20:50:48 BIGLI LAPTOP-4GQDO8IL PageOpen ProductInfoDialog
2017/1/19:20:50:48 BIGLI LAPTOP-4GQDO8IL PageOpen ProductSelectionDialog2
2017/1/19:20:53:13 BIGLI LAPTOP-4GQDO8IL PageOpen FullProgressDialog
2017/1/19:20:53:16 BIGLI LAPTOP-4GQDO8IL Download Play VCREDIST2005SP1ATLX64 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIS...
2017/1/19:20:53:34 BIGLI LAPTOP-4GQDO8IL Download Complete VCREDIST2005SP1ATLX64 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIS...
2017/1/19:20:53:34 BIGLI LAPTOP-4GQDO8IL Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\BIGLI\AppData\Local\Temp\vcredist_x64_2005.log"" "
2017/1/19:20:53:45 BIGLI LAPTOP-4GQDO8IL Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2017/1/19:20:53:47 BIGLI LAPTOP-4GQDO8IL Download Play VCREDIST2008SP1X86 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIS...
2017/1/19:20:54:01 BIGLI LAPTOP-4GQDO8IL Download Complete VCREDIST2008SP1X86 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIS...
2017/1/19:20:54:01 BIGLI LAPTOP-4GQDO8IL Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/1/19:20:54:08 BIGLI LAPTOP-4GQDO8IL Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2017/1/19:20:54:10 BIGLI LAPTOP-4GQDO8IL Download Play VCREDIST2008SP1X64 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIS...
2017/1/19:20:55:45 BIGLI LAPTOP-4GQDO8IL Download Complete VCREDIST2008SP1X64 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIS...
2017/1/19:20:55:45 BIGLI LAPTOP-4GQDO8IL Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2017/1/19:20:55:51 BIGLI LAPTOP-4GQDO8IL Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2017/1/19:20:55:53 BIGLI LAPTOP-4GQDO8IL Download Play VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIS...
2017/1/19:20:57:17 BIGLI LAPTOP-4GQDO8IL Download Complete VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIS...
2017/1/19:20:57:17 BIGLI LAPTOP-4GQDO8IL Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2017/1/19:20:57:30 BIGLI LAPTOP-4GQDO8IL Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2017/1/19:20:57:32 BIGLI LAPTOP-4GQDO8IL Download Play VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIS...
2017/1/19:20:58:41 BIGLI LAPTOP-4GQDO8IL Download Complete VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIS...
2017/1/19:20:58:41 BIGLI LAPTOP-4GQDO8IL Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2017/1/19:20:58:42 BIGLI LAPTOP-4GQDO8IL Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2017/1/19:20:58:44 BIGLI LAPTOP-4GQDO8IL Download Play DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DIRECTX...
2017/1/19:21:00:13 BIGLI LAPTOP-4GQDO8IL Download Complete DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DIRECTX...
2017/1/19:21:00:13 BIGLI LAPTOP-4GQDO8IL Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2017/1/19:21:00:17 BIGLI LAPTOP-4GQDO8IL Install DirectX® Runtime Succeeded
2017/1/19:21:00:19 BIGLI LAPTOP-4GQDO8IL Download Play CM http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM.tar....
2017/1/19:21:03:54 BIGLI LAPTOP-4GQDO8IL Download Aborted CM http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM.tar....
2017/1/19:21:03:54 BIGLI LAPTOP-4GQDO8IL Install Autodesk® Material Library 2015 Failed Download Failed, Installation aborted, Result=1603
2017/1/19:21:03:54 BIGLI LAPTOP-4GQDO8IL Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2017/1/19:21:03:54 BIGLI LAPTOP-4GQDO8IL Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/1/19:21:03:54 BIGLI LAPTOP-4GQDO8IL Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2017/1/19:21:03:54 BIGLI LAPTOP-4GQDO8IL Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2017/1/19:21:03:54 BIGLI LAPTOP-4GQDO8IL Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2017/1/19:21:03:54 BIGLI LAPTOP-4GQDO8IL Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2017/1/19:21:03:55 BIGLI LAPTOP-4GQDO8IL PageOpen InstallCompleteDialog
2017/1/19:21:17:53 BIGLI LAPTOP-4GQDO8IL === Setup ended ===
2017/1/19:21:21:16 BIGLI LAPTOP-4GQDO8IL === Setup started on LAPTOP-4GQDO8IL by BIGLI ===
2017/1/19:21:21:16 BIGLI LAPTOP-4GQDO8IL Path_Length: 148
2017/1/19:21:21:16 BIGLI LAPTOP-4GQDO8IL Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_zh-CN
2017/1/19:21:21:16 BIGLI LAPTOP-4GQDO8IL Launch
2017/1/19:21:21:16 BIGLI LAPTOP-4GQDO8IL CommandLine /PK 128G1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_z...
2017/1/19:21:21:16 BIGLI LAPTOP-4GQDO8IL Current Directory C:\Users\BIGLI\AppData\Local\Temp\_AI38F0.tmp
2017/1/19:21:21:18 BIGLI LAPTOP-4GQDO8IL === Setup ended ===
2017/1/19:21:21:18 BIGLI LAPTOP-4GQDO8IL Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:21:21:18 BIGLI LAPTOP-4GQDO8IL PageOpen LaunchDialog
2017/1/19:21:21:28 BIGLI LAPTOP-4GQDO8IL PageOpen LicenseDialog
2017/1/19:21:21:28 BIGLI LAPTOP-4GQDO8IL PageOpen ProductSelectionDialog2
2017/1/19:21:21:44 BIGLI LAPTOP-4GQDO8IL PageOpen LicenseDialog
2017/1/19:21:21:44 BIGLI LAPTOP-4GQDO8IL PageOpen LaunchDialog
2017/1/19:21:24:30 BIGLI LAPTOP-4GQDO8IL PageOpen LicenseDialog
2017/1/19:21:24:30 BIGLI LAPTOP-4GQDO8IL PageOpen ProductInfoDialog
2017/1/19:21:24:30 BIGLI LAPTOP-4GQDO8IL PageOpen ProductSelectionDialog2
2017/1/19:21:25:17 BIGLI LAPTOP-4GQDO8IL PageOpen FullProgressDialog
2017/1/19:21:25:19 BIGLI LAPTOP-4GQDO8IL Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIS...
2017/1/19:21:25:19 BIGLI LAPTOP-4GQDO8IL Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2017/1/19:21:25:20 BIGLI LAPTOP-4GQDO8IL Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2017/1/19:21:25:21 BIGLI LAPTOP-4GQDO8IL Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIS...
2017/1/19:21:25:21 BIGLI LAPTOP-4GQDO8IL Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2017/1/19:21:25:22 BIGLI LAPTOP-4GQDO8IL Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2017/1/19:21:25:22 BIGLI LAPTOP-4GQDO8IL Download Skipped DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DIRECTX...
2017/1/19:21:25:22 BIGLI LAPTOP-4GQDO8IL Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2017/1/19:21:25:27 BIGLI LAPTOP-4GQDO8IL Install DirectX® Runtime Succeeded
2017/1/19:21:25:29 BIGLI LAPTOP-4GQDO8IL Download Play CM http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM.tar....
2017/1/19:21:29:52 BIGLI LAPTOP-4GQDO8IL Download Aborted CM http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM.tar....
2017/1/19:21:29:52 BIGLI LAPTOP-4GQDO8IL Install Autodesk® Material Library 2015 Failed Download Failed, Installation aborted, Result=1603
2017/1/19:21:29:53 BIGLI LAPTOP-4GQDO8IL Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2017/1/19:21:29:53 BIGLI LAPTOP-4GQDO8IL Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/1/19:21:29:53 BIGLI LAPTOP-4GQDO8IL Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2017/1/19:21:29:53 BIGLI LAPTOP-4GQDO8IL PageOpen InstallCompleteDialog
2017/1/19:21:43:30 BIGLI LAPTOP-4GQDO8IL === Setup ended ===
2017/1/19:21:44:26 BIGLI LAPTOP-4GQDO8IL === Setup started on LAPTOP-4GQDO8IL by BIGLI ===
2017/1/19:21:44:26 BIGLI LAPTOP-4GQDO8IL Path_Length: 148
2017/1/19:21:44:26 BIGLI LAPTOP-4GQDO8IL Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_zh-CN
2017/1/19:21:44:26 BIGLI LAPTOP-4GQDO8IL Launch
2017/1/19:21:44:26 BIGLI LAPTOP-4GQDO8IL CommandLine /PK 128G1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_z...
2017/1/19:21:44:26 BIGLI LAPTOP-4GQDO8IL Current Directory C:\Users\BIGLI\AppData\Local\Temp\_AI7094.tmp
2017/1/19:21:44:30 BIGLI LAPTOP-4GQDO8IL === Setup ended ===
2017/1/19:21:44:27 BIGLI LAPTOP-4GQDO8IL === Setup started on LAPTOP-4GQDO8IL by BIGLI ===
2017/1/19:21:44:27 BIGLI LAPTOP-4GQDO8IL Path_Length: 148
2017/1/19:21:44:27 BIGLI LAPTOP-4GQDO8IL Current Directory C:\Users\BIGLI\AppData\Local\Temp\_AI7094.tmp
2017/1/19:21:44:27 BIGLI LAPTOP-4GQDO8IL Launch
2017/1/19:21:44:28 BIGLI LAPTOP-4GQDO8IL Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:21:44:29 BIGLI LAPTOP-4GQDO8IL PageOpen LaunchDialog
2017/1/19:21:44:39 BIGLI LAPTOP-4GQDO8IL PageOpen LicenseDialog
2017/1/19:21:44:39 BIGLI LAPTOP-4GQDO8IL PageOpen ProductInfoDialog
2017/1/19:21:44:39 BIGLI LAPTOP-4GQDO8IL PageOpen ProductSelectionDialog2
2017/1/19:21:45:06 BIGLI LAPTOP-4GQDO8IL PageOpen FullProgressDialog
2017/1/19:21:45:07 BIGLI LAPTOP-4GQDO8IL Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIS...
2017/1/19:21:45:07 BIGLI LAPTOP-4GQDO8IL Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2017/1/19:21:45:08 BIGLI LAPTOP-4GQDO8IL Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2017/1/19:21:45:08 BIGLI LAPTOP-4GQDO8IL Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIS...
2017/1/19:21:45:08 BIGLI LAPTOP-4GQDO8IL Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2017/1/19:21:45:09 BIGLI LAPTOP-4GQDO8IL Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2017/1/19:21:45:10 BIGLI LAPTOP-4GQDO8IL Download Skipped DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DIRECTX...
2017/1/19:21:45:10 BIGLI LAPTOP-4GQDO8IL Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2017/1/19:21:45:12 BIGLI LAPTOP-4GQDO8IL Install DirectX® Runtime Succeeded
2017/1/19:21:45:14 BIGLI LAPTOP-4GQDO8IL Download Play CM http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM.tar....
2017/1/19:21:50:43 BIGLI LAPTOP-4GQDO8IL Download Aborted CM http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM.tar....
2017/1/19:21:50:43 BIGLI LAPTOP-4GQDO8IL Install Autodesk® Material Library 2015 Failed Download Failed, Installation aborted, Result=1603
2017/1/19:21:50:43 BIGLI LAPTOP-4GQDO8IL Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2017/1/19:21:50:43 BIGLI LAPTOP-4GQDO8IL Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/1/19:21:50:43 BIGLI LAPTOP-4GQDO8IL Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2017/1/19:21:50:44 BIGLI LAPTOP-4GQDO8IL PageOpen InstallCompleteDialog
2017/1/19:21:56:07 BIGLI LAPTOP-4GQDO8IL === Setup ended ===
2017/1/19:21:57:01 BIGLI LAPTOP-4GQDO8IL === Setup started on LAPTOP-4GQDO8IL by BIGLI ===
2017/1/19:21:57:01 BIGLI LAPTOP-4GQDO8IL Path_Length: 148
2017/1/19:21:57:01 BIGLI LAPTOP-4GQDO8IL Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_zh-CN
2017/1/19:21:57:01 BIGLI LAPTOP-4GQDO8IL Launch
2017/1/19:21:57:01 BIGLI LAPTOP-4GQDO8IL CommandLine /PK 128G1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_wi_z...
2017/1/19:21:57:01 BIGLI LAPTOP-4GQDO8IL Current Directory C:\Users\BIGLI\AppData\Local\Temp\_AIF5CC.tmp
2017/1/19:21:58:33 BIGLI LAPTOP-4GQDO8IL === Setup ended ===
2017/1/19:21:57:02 BIGLI LAPTOP-4GQDO8IL === Setup started on LAPTOP-4GQDO8IL by BIGLI ===
2017/1/19:21:57:02 BIGLI LAPTOP-4GQDO8IL Path_Length: 148
2017/1/19:21:57:02 BIGLI LAPTOP-4GQDO8IL Current Directory C:\Users\BIGLI\AppData\Local\Temp\_AIF5CC.tmp
2017/1/19:21:57:02 BIGLI LAPTOP-4GQDO8IL Launch
2017/1/19:21:57:04 BIGLI LAPTOP-4GQDO8IL Download Play SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:21:58:33 BIGLI LAPTOP-4GQDO8IL Download Complete SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/SETUP_x...
2017/1/19:21:58:33 BIGLI LAPTOP-4GQDO8IL PageOpen LaunchDialog
2017/1/19:22:01:35 BIGLI LAPTOP-4GQDO8IL PageOpen LicenseDialog
2017/1/19:22:01:35 BIGLI LAPTOP-4GQDO8IL PageOpen ProductSelectionDialog2
2017/1/19:22:01:41 BIGLI LAPTOP-4GQDO8IL PageOpen LicenseDialog
2017/1/19:22:01:41 BIGLI LAPTOP-4GQDO8IL PageOpen LaunchDialog
2017/1/19:22:01:45 BIGLI LAPTOP-4GQDO8IL PageOpen LicenseDialog
2017/1/19:22:01:45 BIGLI LAPTOP-4GQDO8IL PageOpen ProductInfoDialog
2017/1/19:22:01:45 BIGLI LAPTOP-4GQDO8IL PageOpen ProductSelectionDialog2
2017/1/19:22:05:00 BIGLI LAPTOP-4GQDO8IL PageOpen ProductInfoDialog
2017/1/19:22:05:00 BIGLI LAPTOP-4GQDO8IL PageOpen LicenseDialog
2017/1/19:22:05:00 BIGLI LAPTOP-4GQDO8IL PageOpen LaunchDialog
2017/1/19:22:05:02 BIGLI LAPTOP-4GQDO8IL PageOpen LicenseDialog
2017/1/19:22:05:02 BIGLI LAPTOP-4GQDO8IL PageOpen ProductInfoDialog
2017/1/19:22:05:02 BIGLI LAPTOP-4GQDO8IL PageOpen ProductSelectionDialog2
2017/1/19:22:06:01 BIGLI LAPTOP-4GQDO8IL PageOpen FullProgressDialog
2017/1/19:22:06:03 BIGLI LAPTOP-4GQDO8IL Download Play VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIS...
2017/1/19:22:06:41 BIGLI LAPTOP-4GQDO8IL Download Complete VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIS...
2017/1/19:22:06:41 BIGLI LAPTOP-4GQDO8IL Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2017/1/19:22:06:43 BIGLI LAPTOP-4GQDO8IL Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2017/1/19:22:06:44 BIGLI LAPTOP-4GQDO8IL Download Play VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIS...
2017/1/19:22:07:31 BIGLI LAPTOP-4GQDO8IL Download Complete VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/VCREDIS...
2017/1/19:22:07:31 BIGLI LAPTOP-4GQDO8IL Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2017/1/19:22:07:32 BIGLI LAPTOP-4GQDO8IL Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2017/1/19:22:07:33 BIGLI LAPTOP-4GQDO8IL Download Play DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DIRECTX...
2017/1/19:22:08:12 BIGLI LAPTOP-4GQDO8IL Download Complete DIRECTX http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/DIRECTX...
2017/1/19:22:08:12 BIGLI LAPTOP-4GQDO8IL Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2017/1/19:22:08:16 BIGLI LAPTOP-4GQDO8IL Install DirectX® Runtime Succeeded
2017/1/19:22:08:18 BIGLI LAPTOP-4GQDO8IL Download Play CM http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM.tar....
2017/1/19:22:12:57 BIGLI LAPTOP-4GQDO8IL Download Aborted CM http://edutrial.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{EF2AF73D-38F9-44C1-A2F3-912D41520305}/CM.tar....
2017/1/19:22:12:57 BIGLI LAPTOP-4GQDO8IL Install Autodesk® Material Library 2015 Failed Download Failed, Installation aborted, Result=1603
2017/1/19:22:12:57 BIGLI LAPTOP-4GQDO8IL Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2017/1/19:22:12:57 BIGLI LAPTOP-4GQDO8IL Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/1/19:22:12:57 BIGLI LAPTOP-4GQDO8IL Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
